1 - 19 of 19 Posts
:confused I just bought an intake for my car. But the battery keeps the hood from closing all the way. I want to move the battery but where would i move it to> What should I do? HEEELLLLLLPPP? :confused
what does the battery and intake have to do with eachother?
did you move the battery in order to install the intake?
when i put it in the battery was in between the air box and the intake manifold. So it rest on top of the battery when its in.
what brand intake? are you sure they sent you the right one for your car/motor combination?
Discussion Starter · #14 ·
in your picture you used the stock hose. How didi you do that isn't it too short. Where did you get that rubber hose to extend it from?
kommon_sense said:
Don't relocate your battery. Get that piece of crap intake out of your car. I would return it to where you bought it from. It says a lot when they make a part that won't even let you close your hood.
:stupid
why would you relocate the battery for an intake :confused. there is either one or both of two things wrong with this situation...
1) you didn't install it right.
2) you got the wrong model for your car.
orr u gotta cheap brand... i kinda have the same problem... i bought a bomz intake (ebay intake brand) for my car... it was for my car, but it didnt really fit right also, i had to modify it some....
Yeah you definitely got the wrong one. Sounds like you got one for a 92+.
If you can return it, do it. And get the appropriate intake for your model Civic.
And if you want to know the difference between a CAI and an SRI check the Civic stickies, primarily the one that says "look here first".
1 - 19 of 19 Posts
