why would change the spring in a boost controller? why would you need to do that. a boost controller set to neutral will boost the stock psi. i think you're talking about a waste gate and not a boost controller.so can i up the boost with the controller or do i just need to change the spring
get a good tune and what turbo are you runningyea i new at this i use to camaro do you know any good website cuz i really dont want to blow it up yet
I think he meant either change the spring in the wastegate or use a boost controller. Tough to tell, hes not a big fan of punctuation.why would change the spring in a boost controller? why would you need to do that. a boost controller set to neutral will boost the stock psi. i think you're talking about a waste gate and not a boost controller.
wastegate which uses a weighted spring
manual boost controller which uses a spring and ball bearing.
1. your initial question doesn't translate to what you just said here.I know the spring is in the wastegate it has a 5 pound boost spring i need to know if you can turn the boost up with a mbc without changing the spring
what?Dude i got the mbc installed and i looked around to try to figure out if you can add boost to the 5 psi spring couldnt find out so somebody gave me this website. so you do you know ?
your question didn't make sense hence the confusionThank you that all i needed to know car gets tuned tomorrow
