1 - 11 of 11 Posts
94-01 Integra/92-00 Civic Ractive R-Type Front Strut bar $40
-made to mount on the GSR/Type R holes but I'm adding the hardware needed to run it on an LS/GS/RS/sE
-used for a month, made of brushed alluminum, only reason for selling is I bought a neuspeed front strut bar, as you can see they are very similiar in diameter/thickness wise
94-01 Integra Bomz Racing rear tie bar$20
-painted black
-will probably fit the 92-00 civic too.
-I got it for my car, but I have a type R rear sway bar and mounting points don't line up, the swaybar hardware is in the way
94-01 Integra Tanabe Sustec front tie bar$40
-its slightly bent from hitting some train tracks, but its nothing major and can be easily pushed back
-will probably fit 92-00 civic too
-Extremely lightweight, weigh maybe 1lb, but very sturdy
94-01 Integra Type S sideskirts $80
-made of ABS plastic
Universal APC Super Sport seats $200
-these are pretty high quality, top of the line not the junk they sell at the autostores, retail for about $300 each.
-reclinable, lumbar support etc
Looking to get $600.
Koni Full coilovers
-note this is NOT a set of koni yellows with omnipower/skunk2/GC coilovers...these are the full coilovers made by koni.
-As you can see the shocks are koni yellows, so they are more than rebuildable if they blow on you 5 years from now. Also since these are Koni yellows dampening is obviosly adjustible.
- Currently the drop is set for 1.5"
- These have never seen winter, just daily driver.
Not blown/seized etc.
part # 8041 1152 K1
Miscellenious stuff
rsx type S oem camber plates $10
94-01 integra moonroof assembly(glass + motor)$50
94-01 integra passenger side side skirt $20
Craftsman 2 1/4 ton jack. $30
1 - 11 of 11 Posts
