Hey guys,
I think that i am doing something wrong. I am trying to connect my 4 channel alpine amp to my mono JBL amp. The head unit only has 2 pairs of RCA's so i run those to the alpine amp first. Now here is what confuses me. Channels 1&2 are for my highs and are set to 85hz. Channels 3&4 are for my mid and are set to 60 hZ. There are 2 outputs for my interconnect; one for channels 1+3 and the other for channels 2+4. My JBL is set to 40HZ. Here are my questions:
1. If these channels are set to different Hz, will it affect the mono amp even if you set the mono to 40Hz.
2. There are two interconnect outputs. Do I need to use both outputs, or just one output going to the JBL amp?
THanks in advance.
Sag...
you can use Y connecters to hook up the mids/highs amd and use the rear rcas to hook up the sub amp. If you want to beable to fade front to back you need a hu that has 3 RCA outputs.
