Yes, I did my hole interior in black. What is the question?
Not sure what you mean about inserts? Could you explain, I am in the process of finishing up my passenger front door now so if you need pictures I may have them.
I know what you are talking about, I might not be able to help you because what I did to my door panel is I fiberglassed in the pocket(insert?). so my door is flat all the way across but I can say that I did have problems around the outer edges of the panel because of the round shape. I suggest using 3M spray adhesive and do it in sections, and use a heat gunfor the corners. Sorry I may not be of much help. But why don't you fill the pocket and the speaker area with fiberglass and then you can externally mount a nice set of 6 1/2" speakers on the outside of the panel.
