I have a set of gram lights on my prelude but it rubs a little be when i hit a bump in the road. The offset is a little off. It is +40mm i need to have +45mm offset so that they dont rub at all.
Is there any way to get them to fit right? Is it pissible to take the rims somewhere and get them shaved a little from inside? I would really like to fix them becuase I love how they look on my car.
uncle_el said:
shave your calipers or use a 5mm spacer. problem solved.
his wheels stick out too much so they rub against the fenders.
shaving the calipers wont do anything, and if he uses a 5mm spacer his wheels are gonna stick out even more to a total of +35mm offest.
you need to "shave off" 5mm off from the inside of the wheel, where it mounts to the hub. however i dont advise you do that. you're better off selling those rims and getting something that actually fits.
