Hi guys, i'm thinkng about buying a VAFC for my lude. I have simple mods i.e. CAI, Full exhaust sys, de-cat. In your opinions would i get much gain for the money?
Also can somebody tell me what settings they used for each fuel map, i just want a rough idea.
thanx :)
I'm not sure whether it will do anything for you or not, maybe teh fuel-adding function will, but I don't know that it's a good idea to change your VTEC crossover point when you only have stock cams. The ECU is already set to change the cams over at the right spot in the powerband.
If you plan to put some hot cams in there down the road go for it then you'll be ready for them ahead of time. otherwise there's other cheaper ways to get more fuel.
