My 92 Prelude Si A/C compressor doesn't seem to have the typical plug connector or maybe i am just oveerlooking it. The only wire plug that is connecting to this a/c comeressor is the wire my magnet rod is pointing in the first pictute.
[/URL][/IMG]
You can see the plug it connects to in the second picture.
[/URL][/IMG] Hopefully i loaded them correctly. I have looked and felt all aroud it but can't find another connector. I can't see anything from the bottom because of the crossmember bar. Thanks in advance.
because this is basically a dead site
but don't overlook the clutch power plug either
what sort of problem are you experiencing
Discussion Starter #4
I wanted to check voltage at the ac plug but can't locate the plug on my 92 h23a1 compressor. What's a good active prelude forum. Im not getting any responses from any of them. Is that my clutch power plug? What is it? Thanks.
just behind the clutch is the power plug
it basically operates off the high pressure switch which is pretty hidden on your car's compressor
I know I'm a little late, but just in case you're still snooping around here. Go to Preludepower[dot]com.
