1 - 20 of 25 Posts
chicken said:
is it true that you need to get a wheel alignment everytime i adjust my coilovers?
if you raise or lower them you do. You should put them in the lowest setting, get an alignment, mark on the coilovers where they were set, then get it again later on in the highest you use, and to the same.
Snoopy said:
you dont have too, but believe me, if you dont you'll go through tires like whoa.
yeah.....exactly.....like woa, i gotta get new tires soon just cuz of that. The damage had already been done once i put my camber kit on.
you never really HAVE to do maintenance like this, unless of course you want everything to work properly... my advice is to get frequent alignments (you need them if you are running things like this more often)
what's the purpose of the camber kit?
when you lower your car your tires arent in direct contact with the road anymore and it causes the insides of your tires to wear more. A camber kit puts all the tires equally back on the road and eliminates the bad tire wear.
makes sense, thanks :hug
which kit?
i bought some no namers off ebay, said they would do +/- 3 degrees, POS wont do any negative only +3 so i'm running at 0 degrees, really crappy on turn in now, scares the squirts out of me sometimes, but i've got my tires to last way longer than usual :number1
Matt said:
which kit?
i got a SPC kit.
Well,,, I don't think that I need to get a wheel alignment everytime you adjust your coilovers...:D :clap :lol2
in near perfect shape, i can take a pic if u donot beleve me, ive had the same tires sence may 2000. :number1
hobie237 said:
you are a lucky, lucky, lucky man...
ive put less then 19k miles on my car in the past 5 yrs LOL
luck might not have much to do with it. but yes get a aligment if u change ur suspention especally if ur driving alot
that would explain a lot... lol... i put 13k on my truck alone each year... 5k on the miata, which is going up since thats my main ride right now...
1 - 20 of 25 Posts
