FIRST GEAR IS FIRST GEAR
well, manual or automatic - first gear is first gear (also, sometimes marked as Low). what i have noticed is that in usa folks are very leary to use any gears in automatic except "drive", "reverse" and "park". so, i checked, and cr-v has clearly posted "1" next to the gear shifter, ergo - the 1st gear it is. kinda equivalent of demultiplicator on true offroad gearbox.
now, as of 98 cr-v not having a 4 wheel drive with manual - oh, what a shame. it's ALL WHEEL DRIVE, my bad, same difference if you ask me. for the purpose of this particular car/situation, all 4 wheels start getting torque. of course, we can engage into a lengthy discussion of differences, but why?
standard all wheel drive is listed under features for 98 cr-v ex. also, down below it says: REAL TIME FOUR WHEEL DRIVE. sorry, can't help, i'm not the one who calls it 4 wheel drive/ all wheel drive for the same vehicle.
Built on the Civic platform, the CR-V successfully integrates familiar Honda components into an all-new design. Honda's famous four-wheel double-wishbone suspension makes an appearance on the CR-V, the first-ever application of four-wheel double-wishbone technology on a sport-ute, as does the very familiar four-speed automatic transmission. The 2.0-liter DOHC inline four-cylinder engine makes 126 horsepower and 133 foot-pounds of torque. The CR-V's :clap real time four-wheel drive system :clap is a derivative of the unit that Honda initially offered on their Civic wagon. The result of using all of these car components is that the CR-V looks and feels rather like a car. (1998 HONDA CR-V EX, that's what the owner has)
These are the features that are included on this particular style of this vehicle. To see the features that come with other styles of this vehicle, check the Standard Features page for those styles.
Performance
Acceleration (0-60 mph): 10.2 sec. Braking Distance (60-0 mph): 141 ft.
Road Holding Index: .72 g Base Number of Cylinders: 4
Base Engine Size: 2 liters Base Engine Type: Inline 4
Horsepower: 126 hp Max Horsepower: 5400 rpm
Torque: 133 ft-lbs. Max Torque: 4300 rpm
Maximum Towing Capacity: 1000 lbs. :hehe Drive Type: AWD :hehe
Turning Circle: 34.8 ft.
tires? might be. but i know one thing darn sure: if you spun your wheels on snow and MELTED a thin layer, you ain't going anywhere. water has no friction. that's how skates move so smoothly - they constantly melt a thin layer of ice and create virtually a zero friction layer. ergo - back up into a fresh, fluffy snow. oh, almost forgot: if you are stuck stuck - lower pressure in your tires halfway. BIG SURFACE AREA, MUCHO FRICTION!!
