It will bolt on but you need an ITR throttle cable and I think one or two other parts, I forget which. If you want a bigger throttle body IMO it's better (and cheaper) to just bore out an LS TB from 58 to 61mm, that's only 1mm shy of the Type R's 62mm and should be just fine for most applications.
I got some sensors for ya for cheap if you want from an LS TB.
