1 - 17 of 17 Posts
Here we go! they got the engine in and wiring complete today. all thats left is the exhaust, ignition, wideband, plugs, couple extra units and wires.
I still have to get a tranny, quaiffe, bigger injectors and replace that damn drag 2 kit.
Discussion Starter #5
t3/t04e water & oil cooled
Discussion Starter #9
as much as the turbo will put out. i just need some bigger injectors, tranny and quaiffe before that. i should be able to get about 325 to 350whp with the 550cc i have.
I am keeping the ac for a while but am looking into the lovefab or full-race mani at this time so that may go away soon.
I need help with where to put the moroso oil catch can.
mik'
that turbo is huge good luck with the project.
I can tell you where to put that oil pan in my garage ;) I've got a perfect spot to put it (on my car).
Take care and when you get that BEAST running-post a vid' for us rookies :p
Discussion Starter #11
Well it's all pretty much done now except for the Exhaust. It should be done today or monday.
yo man rmr that not to run too much PSI cause I've heard that prelude Rods can't handle that much pressure, think about investing in some low-compression pistons
Discussion Starter #14
This thing is far from stock and here's the short list of what i have done so far.
Everything has been done to try to bullet proof this thing as much as possible.
Golden Eagle Sleeves
T3/T04E cold side: .50A/R 57trim hot side: .63 A/R stage 3 water cooled 360 deg bb
spearco fmic
Endyn pistons 9:1cr
Eagle rods ESP 4340
OE main & rod bearings
Prodive oilpump gear
ARP studs
Ferrea dual springs, seats, retainers
Stock Cams
Balanced Crank
Walbro HP 255, RC 550cc injectors, AEM FR & FPR
MSD Ignition & Coil
3bar map sensor
Exedy Flywheel & Racing Ceremetallic clutch
GM Boost Controller
honda resistor
techedge wideband unit
tons of gauges
aem ems
2.5" to 3" dp 3" custom exhaust w/ magnaflow wide open muffler
Discussion Starter #17
Finally after 12 months of not having the Prelude it's gonna be started Monday. This has been a very long and patient wait for Nikki and I. John (Secret Services) told me I'll get between 325 and 350whp with the injectors I have now and the dyno will tell. I'll post up some sheets in a couple weeks after the break in and tune is done.
1 - 17 of 17 Posts
