Hi... i have a b16a2 running a standard 6psi jackson racing setup plus jackson racing boost timing controller and high flow fuel pump. at the moment i am still using the "fuel enrichment relay" :-(... lol... so i am thinking about getting the JR MAP controller.
i understand this replaces the fuel enrichment relay as it should map more fuel as it reads an increase in boost?
is this correct?
also... will this be sufficient for the moment or should i also get bigger injectors with the MAP controller?
my other option was an Apexi S-AFC... which would be better?
is this correct?
