i neei info on this engine 92 sohc zc jdm spec
and if it is install like the d16z6
know where i can get cams for my d15b ? and know the head combustioon chamber specs and if a6 pistons can fit ?jdmb18hatch said:the cam doesnt make much of a diference maybe 1-2 hp at most not worth buying IMO....not worth buying a a6 cam for a d15b1 either if u want to buy a cam then buy an aftermarket one that will gain 15 hp not 1-2
PSIKOTICsi said:well if you are talking about a d15b 88-91 civic/crx dx motor then i suppose you can use aftermarket cams that are made for a d16a6
only cams i know for the d15b are for the jdm d15b where you can use cams from the d16z6 since they both have the same head.
