I am replacing the D16z6 in my 1995 EX with a JDM d15. My question is......do they use the same timing belt and water pump? Everything I can find says its a direct replacement engine, but I want to change the timing belt and water pump while its easy to access. I also bought a Exedy OEM spec clutch and new axles. Is there any other parts that I will need, (besides the normal plugs and wires, oil, filter etc.) for the swap? Will the p28 work OK or is there a better ECU to use. This is my DD, I am not building a race car so I dont need anything to crazy. Thanks for any info.
