the only difference in JDM and USDM engines are.....ah22aselude said:man "she pulls like a [email protected]#cht" that was the quote after the shop got thru installing my JDM H22a into my prelude -- they do pull harder but they have more compression, better components, and more horsepower --- most japan spec engines are a lot better than there us counterparts cause here they are made more for fuel economy not horsepower
Ok you need to work on your honda knowledge the following is a list of the known differences between a h22a1 (USDM) and a J-spec H22a98Vtec said:the only difference in JDM and USDM engines are.....
NOthing, they are exactly the same. what makes them different is the gearing.
Damn..beat me to it... another thing you forgot is.. a RED Valve Cover Yoah22aselude said:Ok you need to work on your honda knowledge the following is a list of the known differences between a h22a1 (USDM) and a J-spec H22a
1. compression ratio 10.1:1 us models 10.6: 1 jspec models
2. ecu is programmed to work with octanes up to 103
3. rated at 200ps or 198hp usdm h22as for the same year (4th gen) rated at 190/195
4. bigger fuel injectors
just to name a few -- looks like a little more than gearing to me ,.,
hmm so is there a real big difference here? like how it affects the powerband and other stuff?BlackShLude said:well you wann talk about injectors ! the obd-1 h22 and the jdm ludes have 345cc injectors and the h22a4 usdm engine have 270cc injectors, oh they are bigger...... WRONG ! they are two completly different injectors. the obd 1 345cc are LOW impedence PEAK/HOLD and the 270cc are high impedence saturated............ pwned
Two of the differences between P&H and Saturated injectors is in their speed and the amount of heat they generate.BlackShLude said:well you wann talk about injectors ! the obd-1 h22 and the jdm ludes have 345cc injectors and the h22a4 usdm engine have 270cc injectors, oh they are bigger...... WRONG ! they are two completly different injectors. the obd 1 345cc are LOW impedence PEAK/HOLD and the 270cc are high impedence saturated............ pwned
Can we have at least one thread in this forum where you DON'T bring up your $7k fully built motor... :rolleyespreludedriver99 said:Ya so just imagine how hard a usdm with forged internals at 11.5 to 1 pulls with a fully built head over a stock head!!!! :clap Oh wait I forgot I don't have to imagine!!!!! :rolleyes
