The engine is a Single overhead cam 1.6 litre ZC imported from Japan by me in august 2004. The engine has approx. 60 000 kms and it runs smooth. The tranny is the USDM Si tranny from an 89 honda civic Si. The exhaust manifold is a stock 4-2-1. I just put bosch platinim +4 spark plugs in the engine, and it has 8.5 mm MSD spark plug wires. It is pretty much a direct bolt in to a 88-91 civic the only things that you have to modify is a wire that runs to the distributor, it is a 5 minute wiring job. You will also need axles from a 90-93 integra they run about 240 bux for both. If there is any questions on the engine or about the swap feel free to call Dustin at 913-1505. $900 for engine and tranny, $750 for just engine. I also have a power steering pump and A/C condenser if you want them.
