Jim has been in his new shop for a while, but I can't remember if this is a new number.
Motorvations Motorsports
(205) 661-3600
I put in the Cartech 20005i myself and was able to rough tune on the rich side with the aid of a B&M fuel pressure gauge, electronic fuel pressure gauge, and electronic air/fuel meter. I wish I could remember the fuel pressure settings I used, but they wouldn't apply to you anyways. I'm sure Jim could rattle off a good base setting.
This is how I went about messing with it:
- Complete install and try to use Yellow Teflon tape, as it's more resistant to solvents than the white. The white will also work well, but doesn't last as long. Lifespan for the white stuff is 2~3 years, so it's no biggie. Since you already have the fuel hoses with the correct fittings, you are basically swapping out the JR unit; took me all of 15 minutes to mount and plumb the thing.
- As the engine is running, remove the vacuum line to the Cartech. You'll then set the fuel pressure about 4lb~5lb more than what your current fuel pressure is. This sets the ratio to 4:1 ~5:1 (4lb of fuel pressure to 1lb of boost, for example). This is done by adjusting the screw on the end of the unit and where you will do the tuning. I basically made a few 3rd gear WOT pulls and watched the air/fuel meter and stopped messing with it when I was able to keep the lights in the upper 1/8th of the gauge. When I went to dyno tune with the Cartech with a wide-band, I found I was pretty close with my rough tune settings which were 12.3:1; a tad on the rich side, but better safe than sorry. I started a little on the lean side of 4:1 and worked up to about 4.5:1. If the upper RPM WOT run causes the a/f to fall out of "rich," use your head and get off the throttle. The pull over and raise the fuel pressure a tad. Repeat.
- To adjust the bleeder screw, start with the screw in the fully out position. From there, work the screw inward until you find the fuel pressure ramping to you liking. You need to double check with Jim on the bleeder screw, as I'm uncertain which diretion to turn it.
To be honnest, I have never messed with a FPR before this one. I don't think a PHD is needed to install or tune one, but use common sence and don't make it harder than it has to be.
I got out of the piggyback business, just as the MAP came out. From the people that have it, they love it. I haven't herd anything negative about it. The only drawback is you can't change your injector's size. It seems to be a no headach item; install it and go.
I haven't seen anyone using Zip's products, but the few guys on the net. It sounds good in theory, but the application can vary. I knew a guy in college that was a EE and thought he was God's gift to circuits. He made several piggybacks for his car stereo amplifier and caused an explosion that took one of his fingers. No saying Zip's product will do this, but since I've been very careful of home made/low-level grass roots products.
If I were in your position, I would buy the JR MAP sensor. Not that I sponsor JR, but electronics tend to hold their value and integrity better than mechanical units. If you bought a Cartech and didn't like it/couldn't tune it, you'll find it's near impossible to sell a regulator once fuel is passed thru it; see how far USPS will deliver a package than smells like raw fuel, if you do try to mail it. See if you can find a used MAP off someone that has gone Hondata, as they will sell at rock bottom to break even.
Seek Jim's opinion, as he deals with this day end and day out and could point you to the best deal. Ask if he's got some used units...
