Hello yall, great forum! Im new in here, and this is what i need: i´ve heard that if i wanted to swap my b16a1 for a b18c, all i had to to swap is the engine block and the ECU, the rest is a direct bolt in. Is this real? how ´bout the clutch, can it handle the hp?thanks, keep on driving
ok look. You are talking about a lot of custom work swapping heads and blocks that doesnt need to be done. As long as you have a B-series mount kit you should be able to swap in the B18C (GSR? TYPE-R?) And yes you will need the ECU along with the B18 trans
