Has anyone used this set up:
H22A4 turbo, 440cc injectors, & Hondata/Omnipower 4 Bar MAP sensor?
I used a base compensation from Hondata with a H22, supercharger & 440's.
I changed the MAP to the custom 4 bar but wont start/idle for poo...
I replaced the stock MAP sensor and ECU and runs fine.
Also tried a compenstation from Hondata as stock ECU & changed the MAP to the 4 Bar again, but same results as before.
Any help?
I have a brand new set of ID650cc with clips that will help you get the most out of your setup.
Try to recalibrate ur TPS
Sent from my Autoguide iPhone app
