i jus got my t3 used turbo with internal wastegate and i'm trying to figure out where the wastegate nipple will connect to? i see on other pics taht it connects to the turbine through another nipple but i dont have that nipple on the turbine side? how else can i connect the wastegate?
look for a nipple on the turbo inlet... im almost positive its there
just connet the line from the wastegate to the charge pipe as close to the turbo as possible.
which turbo did you get?
Laters...
[email protected]
are you asking as far as a new turbo, do I do custom orders, yeah, whaterver combination you want I can do.
The question I asked earlier was ment to ask what car is the turbo off of, what size inducer is it, and so forth.
Discussion Starter #9
its okay to connect it to the vacuum lin eon the intake manifold? where is that vacuum line? did you do this also?
