www.hondata.comep3 said:What do you guys recommend to tune my CTR with the k20 engine?
Please look at some dyno charts before saying things like that.CRXtc said:and open airbox takes away bottom end power weather it is a CAI or a short ram....
I'm not saying it's a bad design. I'm saying it's not worth it for the price Mugen is sure to charge. If you want that sort of design, wait for Comptech to release their icebox. It'll be a quarter of the price, and work the exact same way. And Comptech is likely to have theirs available before Mugen does.the mugen airbox is the best of both worlds......it draws in cold air like the stock SEALED airbox and it has the power that a short ram/CAI would have, AND with an AEM CAI or Injen CAI a whole lot of engine heat is transferred into the intake tube due the the fact that they are metal rather then rubber or plastic, which defeats the purpose of a CAI.....
Ah, didn't realize yours was right-hand drive. In that case, if you want to spend the $700 on the Mugen airbox which noone has any dynos results for, go for it.ep3 said:the mugen box is available now for my car - rhd ep3.
Air boxes are going to be the most restrictive they are the ones that hurt power the most, they are designed to starve the engine of max air flow so that the engine will meet emissions better.CRXtc said:a CAI does add SOME bottom end power however it hurts bottom end performance more then it helps it....open air elements are made strictly for high RPM operation not for low RPM operation while the stock airbox is made to make power throughout the entire powerband.......all of the dyno charts will show you that the HP gains advertised are at the peak of the powerband, not throughout it...i have witnessed many dyno runs, done many different mods to my car and other cars, and i can tell you that when i swapped out my intake for a stock airbox/intake tube with a K&N drop in filter my car pulls A LOT HARDER on the freeway and the bottom end doesn't suffer from the open air short ram intake....and as for price, well some people can afford MUGEN, and if you can afford it by all means get it, if they made a mugen airbox for my car i know i would buy it....
