thats what I was thinking too. but the Z1 does have like 9 more ponies or something. soo I was like oh is that just an A1 with tweeked cams and such? So that is what I am wondering.Im not entirely sure, but I know that the a2 is more for performance. Did you check out k20a2.org? Im sure there is an engine discussion on there
only the 05-06 RSX-S has the z1. I honestly forget where the redline starts on my cluster, but i know ive taken it to just under 9k before the revlimiter kicked in.So the Z1 is the 04-06 Type S. I thought all the US K20's redline was the same 8.1. RSX that is
yeah but look at how the motors are tuned.. the A2 hits peak torque right before vtec activates.. So you have a whole power band that makes less torque than your low end power band.K20A2 [email protected], [email protected] 5600rpm, redline of 8100
K20Z1 [email protected], [email protected] 7000rpm, redline of 8500
A2 woiuld be better choice if you had to pick between em, better response. 10hp isnt gonna make a difference if its getting peak power faster
whare did you get that from? better response? Are you just saying that the A2 is better cause someone else said that? Why do you think that?A2 woiuld be better choice if you had to pick between em, better response. 10hp isnt gonna make a difference if its getting peak power faster
its all about the drivers when the motors and cars are that similar. The only thing the z1 really has on the a2 is the tranny, and if they both are running the same tranny, id say its a battle of the drivers for sure. the coupe isnt much heavier than the hatch, and even then, it would have a slower start, but gain more momentumThere is an EG coupe with a K20 and an EG hatch running around with the Z1. The coupe beats it by a car length at the drags. Similar performance, but the coupe, that should lose considering the weight difference and the fact that both cars are using the same tranny..............idk. maybe teh Z1 was raped a lil too much and was running less then it should? Im not sure. Both drivers are good at dragging, and both are stupid and running stock tires/rims. Id at least go with a stickier set of tires if I just swapped a K series in.
the only thing that hasn't been stated yet are the internals, which are very similar. Both motors are very close in pretty much all aspects. to answer your original question, there aren't any significant differences.like I dont know, but so far it seems like the Z1 makes 10 more horesies and revs more.... And I am willing to bet that it is very similar just tweeked around. So we need someone that knows what they are talking about and tell us about them.
well, both of them are the type of drivers where their quarter times are almost always within .1 of each time they run, not .1 between each car, but the same driver, same car, different runs. They are pretty fucking good, considering they have been dragggin multiple cars since they were 14, and both are like 25 now. They always used 4 cyl and 6 cyl cars, no power galiathsits all about the drivers when the motors and cars are that similar. The only thing the z1 really has on the a2 is the tranny, and if they both are running the same tranny, id say its a battle of the drivers for sure. the coupe isnt much heavier than the hatch, and even then, it would have a slower start, but gain more momentum
no, the z1 uses type r camsits all about the drivers when the motors and cars are that similar. The only thing the z1 really has on the a2 is the tranny, and if they both are running the same tranny, id say its a battle of the drivers for sure. the coupe isnt much heavier than the hatch, and even then, it would have a slower start, but gain more momentum
is that the deal?no, the z1 uses type r cams
No it doesn't actuallyno, the z1 uses type r cams
Bumping old thread to provide correct information.no, the z1 uses type r cams
