try installing the perches upside down, meaning you probably had them the wrong way. They should be dished "down" on the shock so that it is abotu anther inch lower.
If the gaps are 1" different then that is normal.deMad10 said:But cutting the bumpstop won't effect how the car sits though.
I say take measurements of the distance from the ground and compare. That will tell you if something is really wrong.
You would think with the shocks set to complete opposite stiffness that it would not be good, but not sure. Will it actually lower the car 1/2" by doing that thoughgju714 said:The springs settled a bit, so now it's about an 1" diff. I'm problably gonna move the front perches to the last(lowest) setting, this will give me another 1/2" for the front. Anyone think there will be any negative effect when the front and rear perches are set at different heights? At the moment both are set in the middle position.
