Replaced the radiator and upper and lower hoses in my car, 94 Civic LX with D15B7 and auto-trans.
Everything fit fine except the fan didn't fit properly. The Koyo radiator didn't have two holes for the bottom of the fan frame. So, I took a pair of pliers and broke the plastic on the fan frame so it would fit on the radiator. There are only two bolts holding the fan to the radiator but the bottom is held in place by two stubs protruding from the bottom of the radiator where two bottom bolt holes were on the OEM radiator.
Dayco hoses fit fine.
Replaced the auto-trans-fluid and the coolant. Car runs a little cooler (as per the temp gauge).
