turbo-kits said:
I am also thinking about getting the AGXs.
Should I get the Koni's instead?
What are the benefits of the Koni? AGXs?
Thanks
well Koni's are only dampening adjustable but are height adjustable....which I could care less about.
AGX's are dampening adjustable and also they adjust the stiffness pushing in...compression adjustable.
But there are 4 settings....setting 1 adjusts both the compression and dampening to soft while setting 4 is stiff on both dampening and compression.
Koni you can increase the dampening tons and not have a hard compression stroke since its the same no matter what.
personally I like my AGX's better than Koni's but its just My OPINION.
