21 - 40 of 62 Posts
Premium Member
what's 2step? is that lsd?
.........:bash
two step is a rev limiter you can set to launch with. For example...MSD'd digital 6 ignition has a rev limiter and a 2-step. The rev limiter you set as the max you will let your mtoor trun..in my case...8600.....the 2step you set for your launch rpm..in my case..7500..When you apply 12 volts to the 2step system it will use that rpm to limit the motor..when you release that 12volts it goes back to the max rev limit..basically all you do is runt he wire fromt the two step to a button..and the other side of the button goes to a 12volt source
Premium Member
Premium Member
.........:bash
i have a daughterboarded ecu. my tuner set my 2 step at 4800 rpms. cool thing about how he did it is that i now build 7 psi whenever i use my 2 step so i get a launch wiht 80 percent of my boost from the get go. really nice to use against awd cars
Premium Member
Premium Member
4800....you're on street tires..step up to some slicks man
Premium Member
yeah 4800 my street tires are also 8 inches wide. slip the clutch and i get nice launches. but i want to hit up the 1/4 mile track just to know what i'd run on street tires. and besides i'm rwd not fwd. not as bad for me as it is for you
ohh.... i think i have that... i slam the gas and it stays on 3000rpm it makes this cool sound too... if i press the gas slowly to 5000rpm and then just slam it... it will do the same... and i take off with 6psi doing that... only thing is i spin for days.
Premium Member
meh
Premium Member
you're fwd. physics is your enemy, you need to ease the clutch and get lsd with better tires.
Premium Member
you totally need kicked in the nuts
Premium Member
yeah i want to get some new tires and see how much faster i can take off... i know nothing on putting lsd in my car... too expensive.
Premium Member
its actually relatively easy...but buying an lsd is rediculous...damn things are expensive
yeah my friend was telling me he'd do it for me but it's gonna be quite a bit of money... he's also the one helping me build my engine... just need rods and bearings and i'm done :p i've seen some videos of awd civics... they use the drivetrain out of a wagoner or somethin like that.
Premium Member
quality ones are expensive. but just shop around and you'll be good. open diff ftmfl!!! i only have viscous and i hate it. but i'd kill myself if i had an open diff
Premium Member
yea...dont do it..those trannies are weak as hell..they use the old civic wagon trans or you can use a crx trans..an all around waste
21 - 40 of 62 Posts
