ok, this is my problem, i gotta get a clutch and flywheel this week!!! and i want a lightweight flywheel, but i dont know how light i should go, i can go from 6.5 lbs to 18 lbs (stock) but i dont think i should get 6.5 its a bit TOO light, and i think i would stall just about everyday..... so i was thinking maybe 9.5 lbs??? i dunno, i need help, ok this is my question, lightweight flywheel makes you accelarate faster, thus meaning you go faster quicker... so i was wondering on a Stock CRX if you just put a flywheel what should you expect to run at the track??? (mine is not stock) i have a worked head port and polished with street cams, valves, retainers, etc.... also i was wondering what do you guys run for fuel pressure??? cause i believe im taking in too much air in and not enough fuel..... Please help in my questions, thank you!!!
