1 - 11 of 11 Posts
What up. I'm thinking bout lowering my 4th gen 2 door lx. Will 94-97 Springs Fit perfectly on a 90-93 Accord? I'm not talking bout the V6 ones. Because I found a pretty good deal and was thinking to get it done.
Also...i've got some brand spanking new tires...but if I lower my car with some Neuspeed Sport Springs (1.75F, 1.5R) will i need a camber kit? Would maybe an alignment bring the camber back into line? I really dont want to jack up my camber because the tires are brand new(and damn expensive!!).
Thanks for the help.
-Nas
most springs apply to 90-97 accords. but check the part numbers just to be sure.
when i lowered my car with H&R sports (1.5/1.75), i had pretty bad camber problems. unusual for that drop but it did happen.
safest thing to do is to lower it, align it and see how you are from there.
Discussion Starter #4
uncle_el did you get an alignment done after you lowered it or what? have any pics of your car with those springs? Thanks a lot
-Nas
nas00 said:
very nice
thank for all your help
17's???
i have 15 inch 94 EX alloys
i have a Eibach Prokit and with 15 Ex rims and it is low enough for me, i think it is the perfect drop with 15s.
First of all, I am biased to lowering a car without adding a camber kit the first time around. When you lower your car (whatever drop) it automatically gives it a negative camber; which in effect gives you uneven tire wear. An alignment will not correct the camber; that's why they make camber kits.
You're better off doing things right the first time and be safe than sorry.
coil overs will fit on 90-97 accords. But just springs will not fit you have to use 90-93 springs. I tried before and the rear springs are to big daimeter wise and won't sit on the strut properly.
1 - 11 of 11 Posts
