the LS engine is the 2nd highest trim on the integra line. depending on how you want to modify the LS engine,if u go force induction the LS engine will be better than goin with the GSR engine. but if all motor the GSR will be better.
What is LS engine? Is it from Integra LS? I thought LS was lowest trim of Integra. Isn't GSR engine better for tuning?I'd say get an LS engine and turbo it.
HybridJDMHonda said:The B18B(LS engine) is a great engine to turbocharge because of the lower compression ratio and the fact that the bottom end is fairly strong(considering its stock). The rod stroke is also desirable if you are looking into turbocharging.
you can get a turbo for around $2500 for that motor.RichyRichaPC said:ya, but how much is a turbo for that engine?
I have a 97 dx... I don't know the engine name/type, but is it a direct drop? or will I have to change the tranny too?
YES, you'll have to change the transmission.. You have a D series engine.. the LS motor (b18b) is a B series.. B series is not compatible with D series.. Everything has to go.. You'll need the axles, ecu, motor, trans, shift linkage, ect..RichyRichaPC said:
i wish there was a place that could do an H22 swapRageAgainstNate said:instead of dropping 2Gs on an engine and 3Gs on a turbo get a beast, thats right a H22A. The engine will run you about 3500 and if you can't install that shit yourself then it will probably run you a G to get it popped in.
LS is the 2nd trim, but i heard that you can get more power from the ls and gsr, especially when going turbo.EK9 said:
for $4500 including instalation.
but thats never the case. usually the H22 swap will run you
more than the typer swap and your car will never be the same
and you wont be able to return your car back to stock conditions.
