If I were to put some JG mild cams into my LS do I need to do a valve adjustment... some people has done this before with out a valve is it gonna affect any aspect of performance...
Its a must everytime you install a new set of cams...make sure the valve lash is in the recommended specskinghawk said:Its standard to readjust your valves and I feel its good idea to readjust also........not doing so would either allow to much slop ( different tolerences between cams) or them being to tight....... both ways you get a shitty running engine, bad gas mileage and no guts
