is it a good idea to put a 94+ ls tranny in a 94+ gsr any benefits at all..??
J jmcy · Registered Joined Sep 8, 2002 · 113 Posts Discussion Starter · #1 · Sep 16, 2002 Only show this user is it a good idea to put a 94+ ls tranny in a 94+ gsr any benefits at all..??
S skidtron89 · Registered Joined Apr 3, 2002 · 1,052 Posts #2 · Sep 16, 2002 Only show this user The only benefit is higher speeds in each gear but it will take you longer to attain them......also lower cruising rpms.
U uoboarder · Registered Joined Jun 9, 2002 · 1,208 Posts #3 · Sep 16, 2002 Only show this user He's right. Unless you're planning on attaining some high speeds buy use of a turbo then its probably a waste of time.
1 1Greyteg · Banned Joined Feb 11, 2002 · 2,834 Posts #4 · Sep 16, 2002 Only show this user In a nutshell the last 2 postings are correct. The GSR tranny is of closer ratio gearing to better benefit the B18C1's peaky low torque motor. Unless you are doing a monster turbo, you will not benefit the car with an LS's tranny. A.
