Alright! i Recently picked up an LS motor with a GSA tranny to put in the hatch! :clap
My plan/ goal is to do some mant. to the motor, replace some parts (gaskets, clutch, flywheel, timing belt, water pump, ect, ect) Which is happing now, and while this is taking place find a turbo kit and im going to have the swap + the turbo install happen at the same time! :wow
The only thing is i need help with Turbos. I new to the boosted world... Can you guys point me in the right direction? For now im looking for low boost about 6-7 pounds. Used, homemade, e-bay,somthing, but i dont know what im looking at....
Any infomaion or links to websites is good!
B18b is a very good platform to start with. If you piece your own kit make sure that you stay away from a FMU. Cheap is good but when it comes to fuel managment please spend the money on something good.
b18b as long as they are in good shape, check the compression and do a leak down to be sure, you can boost 12 pounds and not have to worry about much as long as you have a good tuner.
Discussion Starter · #5 ·
ezeedee said:
you wanna piece together your own kit right? thats shat it sounds like.
http://www.hond a-tech.com/zerothread?id=1263795
read that, its a pretty good writeup imho.
i love your green wheels btw.
what kind of power do you want to put down?
Well i wanted a used one and i was gonna upgrade parts later, but if i can figure it out i might make my own.
I hoping for about 200whp on abour 7-8psi when i have the motor+turbo installed. Once agien i dont know turbos too well yet, but i think that will get me there. After the install i will start saving for internal motor work and i want to be able to run 250whp...thats later thought....
green wheels! :w00t
klungemonger----------->pm sent
green wheels! :w00t
you can hit 250whp on a stock block with a good tune. no need to upgrade internals unless your getting closer to the 300whp range.
