don't worrie about your bottom end, well, and you can correct me if i'm not wrong but i belive that you need to be careful with that bottom end, i know there is a post on here that has a link to a web site that shows you why you need to be careful with the ls/vtec, it says something about, if it was so great then honda would have already done it, if anyone knows i think it would help him out a lot, i know that with the gsr ecu you have to have a knock sensor, that ecu will throw a code if it dosen't find the knock sensor, the p28, or getting your ecu chipped is a better way, or if you add a knock sensor then that is good to but you will want to be careful with that rev limit. but agian i say do the search you can find so much on this site and on the net abut this subject.
