klungemonger said:
Why would he take an LS block then replace the internals with CTR stuff to make it a 1.6 liter??? He can just get the B16A and save the hassle and expense.
he isn't.
do you even know the components of a ls/vtec? you build the bottom end with better pistons, and build the head with either the b16a, b18c head. the head is where you build it with better cams from the likes of a CTR.
ls/vtec's are okay, if you are into tearing you motor down alot. i guess there great for racing, but... I've heard of them only lasting 6 month's or so. they were never mit to be. i would go for the real vtec motors. good, luck...
--just like anything else, if it isn't built correctly, then it will not last long. you also have to take into account on the usuage of the engine, isn't being abusively driven? conditions? daily driver? etc...true, honda does make great motors, but to combine VTEC, with torque that honda enthusiasts sorely been missing in factory engines, this option gained many...
An Ls motor out of an 2nd gen integ will work for LS Vtec, but the motor is totally unreliable. If ur looking at the cheaper swap definitely go with the b16a. If ur looking to be quick as hell go LS Vtec, because i've seen a grip of Ls Vtecs that run low as high 13's on all motor. And the LS VTEC motor usually only lasts up to 10,000 miles before it goes to shit. And if you add all the rebuilds and work that goes into the motor u could probably build a LS Turbo or and B1bc5 all motor, or even a built LS and shoot mad nos for the same price. If I were u i would go LS its a good strong heavy motor, and if u blow it, u could easily find a new bottom end for $300 or less.
everyone has their preference and which path they want to go, as far as reliability, please, don't knock it unless you've done...i mean, on a regular basis, i talk to jayman320(integra moderator) about his ls/vtec and that's lasted him for about 2 years, with mileage reaching a little over 50k...and whats more sweeter is that it runs 13s.....randyman(another integra moderator) has had his b20/vtec for a little over a year....and then there are few others in my neighborhood who have a number of hatchbacks with b20/vtecs and/or ls/vtecs....it just matters who does it, and how well it is built up....
your rationality is like saying that turbos are unreliable....but you take out the questions of how much PSI is it pushing? or how is it being driven? how well was it built to handle X psi? what kind of turbo system was it?
the discussion about ls/vtec has been discussed over and over again, and there is all the necessary information if you just use the search function....everything from what you will need, price ranges, questions, suggestions, comments, and everything in between...from the more knowledgeable tech guys...
but if you want to lead astray from the high costs, because frankenstein engines are a big investment, then stick with the b16, its a great engine in itself...
