1 - 14 of 14 Posts
I was thinking about doing a ls/vtec or b18c swap into my 1991 Integra LS. I read all about if you do ls/vtec right and spend the $, there should not be a reliability issue.
I found this link this week. And basically it is suggesting instead of ls/vtec or b18c (which causes more $). Why not put in a b16a1 engine and built it to 210-220 HP. I like to hear what you guys think ...
http://www.hondastyle.com/news/wmview.php?ArtID=33
Joe
i read his article...and it is ok..but still crap...
look at all that work he is talkin about????....pistons, rods, sleeves, crank.....and he has the nerve to say it is same cost of an LS/VTEC?????!!!????
listen..no matter what u do with the 1.6L motor..u will still lack the torque...and no matter what honda uses to make HP, torque is what engines NEED.
a stock LS VTEC with cams is known to hit the 206 mark,,,,(this is the GSR head, go to www.importreview.com and check the dyno sheets.
when u have more torque..u have higher limitations... thats the bottom line...
yes my LS/VTEC might not be reliable (i hope not, up to date it has never let me down, no smoke, no problems)...but the cost of you boring out the B16 and then replacing pistons..i can just build a LS/VTEC with a B20 and replace pistons for a cheaper price.
LS/VTEC's are great motors, they just need more attention is building them...it not about the money, just take your time and do a perfect job..and you will reep the benifits, of making HP..
FROM BOTH TORQUE AND RPMs..
later
B16A's are no good in integras. I have seen this swap too many times. The B16A doens't pull any harder then the LS they had in there before.
Discussion Starter · #4 ·
ls/vtec / gsr swap / type r swap
chingro,
which head do you have ? b16a or b18c ?
For power and reliability, do you prefer going ls/vtec better than b18c1 or b18c5 ? Assuming ls/vtec is $5k and b18c1 is $5k and b18c5 is $6k. What would you suggest ?
Thanks,
Joe
I would choose a B18C1 over LS VTEC if the price are the same. In fact, here is the order I would go...(1) B18C5, (2) B18C1, (3) LS/VTEC even if the B18C5 costs 1K more.
The problem with LS/VTEC is the stock bottom-end revving to 8000RPM redline. On the other hand, getting a B18C1 or B18C5 would be a straight forward swap. Just drop the motor in and go...and the reliability of B18C1 and B18C5 motor is top notch.
Re: ls/vtec / gsr swap / type r swap
91int said:
chingro,
Joe
hehehe...i wuz wondering when one yahh will ask that...
look at my signature:cool: ---
a ls/vtec does not cost 5k....if i had 5k i would have a type R in my car right now.
...i not sure how much it will cost yall...that i up to u to search around....
i got the COMPLETE head swap and LS gasket for $400....
i did the swap myself..took me about 2-3 days...(about 3.5 hrs a day)
well later
Re: Re: ls/vtec / gsr swap / type r swap
well later
So you just did the head swap? What kind of numbers are you putting down?
i really dont know..but i can give u an idea
well i not sure how much....
with the GSR ecu..i beat gsr's easily....
but with the LS ecu, they have me on the top end..(my redline is at 6800)...but even with the LS ecu i still beat the B16A's even in civics...
i use the LS ecu for daily driving..and GSR ecu for racing...
with both i have the VTEC effect cuz i have the fields conrtoller
english town opens soon..i will get a time slip for yall...
chingro said:
i did nuthing..
my mechanic dis something that fools the ecu....but the check engine light sometimes come on.
but remember i only use the gsr ecu when racing.
Why do you only use the GSR ecu for racing?
So for daily driving you use the stock LS ecu and just use a V-AFC to control the vtec?
ans: higher rev limiter is the main reason
ans: yes i use the LS ecu for daily driving, it burns less gas, and VTEC controller (fields) open VTEC.
1 - 14 of 14 Posts
