Hey whats up here my question,
I have a 92 LS DA fully built head, with about 70 miles on the motor, it was built by a knowlegable mechanic, it has a small size turbo not too sure what size it is but fairly small to make room for the A/C assembly. Anyways I was told that it would need an after market radiator, so i added a fluiddyne radiator, the car doesnt really overheat when drivien normally, boost kicks in at about 3500rpm so if driven under its fine, once the car starts to boost the check engine light turns on then a min later the temp needle starts to rise fairly high all the way to the red level. If i turn off the car the needle goes back to normal temperature level. my mechanic says it can be 4 things the oem temp cluster is giving a false reading cause when the temp is at red or hot level the engine is running normally with no signs of overheating. He said maybe the temp sensor is not working properly, or might need a aftermarket thermostat or it the way it was tuned with Hondata and might need to be retuned. From what i know the car is running rich i think, i get very little white smoke. whats do you guys think ?
Im running a stock exaust but from the headers back it has a flex pipe then 3inch piping to a stock exhaust, would getting a after market exaust help lower the temp ? i like the whole stock sleeper look and would like to avoid unwanted attention. Woul hollowing out the stock exhaust give any results ? is it worth doing ?
