wondering if ne one knows if its safe to run a cam with a max lift of 12.446 if my max lift on my springs are 12.5. also im running 11.5:1 pistons. shifting at 7500
aftermarket pistons? i ask b/c the valve reliefs are deeper and therefore you can run a larger cam. btw your shift point shoudl be determined by the camshafts, after they are degreed upon installation, you get ona dyno and find out where they stop making power. that's your max rpm.wondering if ne one knows if its safe to run a cam with a max lift of 12.446 if my max lift on my springs are 12.5. also im running 11.5:1 pistons. shifting at 7500
