Luminics - High Performance Halogens
Exclusive Superhonda.com Members Deal
http://www.luminicsusa.com/bulbSeries.asp?BulbType=SHCombo1
You can view all the Luminics Superhonda.com members combos only through the link above.
Lumnics Pure Blue Halogens - starting at $40.00
Description:
If you're looking for blue, these are the bulbs for you. Pure Blue series by Luminics feature a premium deep blue coating for a clean look. The rich color output is the perfect way to set your car, truck, or motorcycle apart from the crowd.
Each order comes with Order Confirmation/Tracking Emails and a FREE LED Keychain!!!
Lumnics JDM Yellow Halogens - starting at $28.00
Description:
Luminics JDM Yellow series halogens were designed to provide superior visibility in inclement weather and provide a stylish yellow output that is sure to turn heads. Traditionally used primarily in foglight applications, Luminics JDM Yellow have become increasingly popular as an alternative to traditional white headlights. Available in all popular bulb applications, including 800 series bulbs - give your vehicle a fresh new style with a set of Luminics JDM Yellow Halogens!
Lumnics Ultra Violet Halogens - starting at $40.00
Description:
Luminics Ultra Violet series halogens provide a super-white purple hue that is often mistaken with High Intensity Discharge (H.I.D.) lights often found in European luxury cars. The bulbs provide an increase in light output, and a unique style that's guaranteed to give your car or truck with a fresh new look No modification necessary, plug and play.
Lumnics Ultra White Halogens - starting at $21.00
Description:
If you are looking for an affordable upgrade over your stock bulbs we recommend Luminics Ultra White Headlight Bulbs. With Luminics Ultra White Headlight bulbs you will have people asking if you what kind of HID kit you installed. We highly recommend this upgrade!
Lumnics Titanium White Halogens - starting at $60.00
Description:
Luminics Titanium White Halogens produce a brilliant white output that's out of this world. The metallic coating produces a super-white light pattern that slightly changes color from different angles, similar to an HID setup. Available in all popular bulb applications - give your vehicle a fresh new style with a set of Luminics Titanium Whites.
