Slowpoke said:
What is a a way to make my civic steering responisiveness improve? I feel like I have to turn my wheel a half a turn to make a sharp turn.
I'm not sure how far you want to go or how much you want to invest, but I took the assumption that you want to keep the car as close to stock height and ride quality as possable.
- get a set of good springs that drop your car an inch or less.
- high quality shocks or adjustable even
(as much as I do not like shameless plugs, the set up CiViC2000 listed would be very nice)
- sway bars front & rear
- strut bars (front upper makes the most difference)
- better tires (more performance oriented)
- a small amount of negative camber or small amount of toe in (this wears tires faster so be careful how much you go)
- get an alignment (it might be off right now, toe out causes slower stearing responce)
