MAP SENSOR HELP!!
1003 Views 3 Replies 4 Participants Last post by  CRXtc
Will a MAP sensor from a D16A6 fit on a D16Z6?? and are they in the same location??
The MAP mounts on the firewall near the Serial Number. Are they the same-check with your local honda dealer or do a search.
They won't interchange. The A6 is mounted on the firewall. The Z6 is mounted on the throttle body and they are completely different in shape. I know I have both. The old one is in my kitchen I think.
THEY WILL NOT WORK!! just like skidtron said...and even if you somehow got them to hook up your car would run rich
