I just installed a set of Tokico Illumina's and Eibach Pro-kit lowering springs. Now my front driver side sits lower than the front passenger side, and the rear driver side sits higher than the rear passenger side. The difference is about 1/2". The Eibach springs were moved from my factory struts to the new struts ( already broken in). My question is this: Do struts have a seating/braking in period? Has anybody else experienced such a problem?
i have the same problem, but both front and rear of the passenger side sit higher than the driver's side. i have heard this is a common problem, especially with civics. not sure about yours though, seeing as your rears are reversed. maybe the springs aren't seated / installed properly?? ive also been told that its the bushings that cause this.
