PupaScoopa said:
When you listen to music in your car without any EQ with your head unit's bass/treble set to 0; the sound will not be flat. What I mean by flat is if you put a real-time analyzer (RTA) in your car while playing some white noise (sounds like static that plays across the entire range from 20hz to 20khz) you'll see some regions that are louder and some that are softer.
If you want the most accurate sound quality, you'll strive to make everything flat. With an EQ and RTA (while playing white noise), you can can boost or cut certain frequencies to accomplish this.
Have you ever heard a system tuned perfectly flat using an RTA?
They sound like SH!T.......NO ONE tunes their systems perfectly flat...why? They sound unnatural. The goal of RTA testing is to provide a baseline or a starting point for your tuning.
The goal is not to create a flat line across an RTA, the goal is to have smooth transitions. An EQ is there to adjust for peaks and irregularities in the system's response. For example, IASCA Street competitors are tested to see that there are no band-to-band deviations greater then 6dB and that all 30 bands are visible...that's it.
Keep in mind that many competitors have separate EQ settings, or even additional EQ's to pass this RTA test. Why? Because they can make their car sound better without trying to get a perfect RTA curve at the same time.
If a system tuned flat to an RTA also sounded the best, why would all of these competitors go through the trouble of adding more eqipment or making changes to thier gear on the fly?
Need more evidence? IASCA will be dropping the RTA portion on the score sheet. Why? Two main reasons....the first, not all shops have an RTA on hand....this means that more shops can hold contests, exposing more people to the "sport" The second reason....an RTA is a terrible judge of SQ. With the new format that allows you to make adjustments between stations, it has become a pointless test.
Remember, an RTA is a tool, not a subjective test of a system's sound quality. Trust your ears!!!
BTW, it's called Pink noise, not white noise.
