I'm working on a 2008 MDX with the 3.7. A bolt mounting the serpentine belt tensioner has broken off. The tensioner is shaped like a figure eight, the upper circle being the pulley and the lower circle houses the spring. The bolt going through the center of the spring is the one broken off. I've tried a lot of things to get it out with no luck. I tried to find an exploded view of the 3.7 engine, to see if this bolt is screwed into the block itself, or into a bracket that could be removed. I haven't been able to find such a diagram. Does anyone know if this bolt hole is in a removeable bracket, or does anyone have an exploded view of the front of this engine? Thanks
