Yes as Chewie said , check your fans first. If your fans are not spinning then you could get HD errors. Most of the time though if a cpu/power supply fan is dead your PC will not boot at all (no beeps) .
Is your Hard Drive spinning ? Open the case and feel your HD when you boot up . If it's not spinning check the cables to make sure they are pushed in all the way. Also try a different power cable. Your power supply should have extras.
If the HD does not spin when your PC is powered on then you have a bad HD or possibly worse a fried motherboard.
Re: ....
If it wasn't spinning lol, he wouldn't be running windows, not being able to even have the option to restart.. so that's not the problem.
Check out this article HondaPimpSi.. http://asia.cnet.com/itmanager/netadmin/0,39006400,39047788,00.htm
Me is the worst windows microsoft has ever made!
Xp isn't that bad, and it shouldn't cause a meltdown
Check your wires, listen to your fans to see if they're making noises. If you're sure it's your hard drive, then bring it to the professionals to get it fixed, but it'll usually cost alot. so i'll recommend u buying a new one, unless you have something really important inside the hard drive.
