Ok guys. Just put a mini-me in a friend of mines car. It is a D16Y7 block with a D16Y8 head. It is in a 1992 CX hatchback using a P28 ECU (stock). Our issue we are having is this: The car idles perfect. but from idle to about 2500-3000rpm, it is VERY sputtery. It goes away after the 3000rpm mark and the car takes off like mad afterward. One discrepancy though is that we may have used on intgra injector. I had like 12 injectors laying around in a box, but they were all obd-0 or obd-2. I had one obd-1 injector left and I think its from an integra. Would that cause any issues with the idle? Do I need to do that funky distibutor trick for the mini-me? I don't wanna leave my boy hanging like this. Thanks.
did you set the TPS? What dist did you use? What year is the head, and whats the Intake manifold from?
lugnutRS said:
What do you mean?
did you set the voltage on the tps..the tps is adjustable, at idle you want .45 volts and wide open 4.5 volts.
Just use a voltmeter to calibrate the TPS...like he said,...., .45 at idle...4.5 at WOT.
Also integra injectors and civic injectors are both 240cc so it shouldn't make a difference.
