I just recently in the past 1,000 miles changed my spark plug cables, distributor cap and rotor, ignition coil, and fuel filter.
The past couple days, the idle started to get a little lower, and a little rougher, and it misses quite a lot now.
I just wanted to get your guy's opinion on things before i start diagnosing.
I'm going to check the plugs tomorrow. I doubt it's that though for some reason, they were new with my cylinder head rebuild 4,000 miles ago. They're NGK G-Power spark plugs.
Could it possibly be the fuel injectors?
My oil is awfully thin as well. The rocker arms are definitely clicking at me. They were all adjusted with the cylinder head rebuild as well. Could it be that they need readjusted already? Would that cause it to misfire? I'm running 10W30 regular engine oil. Should I switch to a heavier weight? What weight?
Thanks ahead of time, I just hate diagnosing on my own.
I like to hear other people's input.
