i plan on putting a b18a1 into a civic, but i was wondering will i need new motor mounts or will the ones from the first motor work? or would you recomend getting new ones just cuz?
yes u will need new motor mounts, that have to be install at different locations than stock. try hasport.com they sell kits.
civic 89-91? 92-95? 96-00?
Use stock motor mount and get a motor mount insert kit from energysuspension......
From the web site:
"are engineered to handle additional torque and horsepower you may have added to your vehicle as well as reinforce weak, worn and broken O.E.M. mounts."
......and it is a LOT cheaper than hasport;)
b18a into 88-91 you'll need aftermarket mounts.. same mounts for b16a into 88-91 civic..
b18a into 92-00 you only need mount kit w/ cable conversion or change the bracket under the timing belt and rear of car
