Who said anything about advancing timing? The stacker is the most basic ignition system. You can't advance timing or anything on it. It just amplifies the spark power or whatever it's called, so yes it will. Just make sure you get the one for the eight-cylinder one since that's the only on for coil-per cylinder ignition systems, like ours.munkeysoup said:as far as i know there isnt anything we can use to advance our timing w/ the exception of the new DI unichip that should be coming out soon and the new AEM ECU that will be out in a couple weeks.
