ill be installing the zex this weekend, along with this rpm activated window switch.
i dont understand how to hook up this window switch though..
it says to run:
black-ground
white-msd output terminal on my 6a
red-switched 12v
yellow-circuit ground on the device you plan to activate
questions:
so do just run the yellow wire to my zex ground?? if so, do i ground the black wire on the zex kit at all??
next..can i run my zex activation switch andddd the red wire from the msd window switch into the same switched 12v slot that i have on my fuse panel that is only one left unused??
also if i unplug the battery at anytime...will i have to recalibrate my nmu for the zex??
